Cleaning AEM Brute Force filter
vatahoelt
NoVa
Should I use anything special? Or will some diluted simple green get the job done? lmk thanks.
Administrator
I'm not sure if the aem is different but with my k&n and airaid filters I've always just rinsed with water and that's done the trick...
V
vatahoelt
NoVa
thanks for the reply. ended up using some dish soap and warm water. man was that water dirty
TheFuzz
Idiot Police
Spurbury, VT
Yeah the dry filters are easy. They sell "cleaning kits" for them just like the oiled filters, but I've found that soap and water works fine. Just make sure it's good and dry before you slap it back on and you're golden.
Max
Mile High
Denver
Simple green works best, just refrain from using high pressure water or air as it may damage the filter. You can re-install the filter even when damp, just be sure to rinse the filter thoroughly.
dwmmatt23
central valley cali
i have the AEM brute force and i spray it with simple green, let sit for awhile, the have a bucket with water in it thats filled up to the top of the filter line when it sits in there, dunk it a few times without letting water go over the intake opening, dump water and fill with clean water, repeat dunking and filling with clean water till no more dirty water appears, i spin the filter in the air till most water spins out of it, then let dry overnight
Administrator
Every 6k miles or so....I'm sure some go longer than that...
Well Worn Chevy
