clickin,tickiin sound
texaschevyryder
LAWTON,OKLAHOMA
there is a tickin or clickn sound coming from da rear right wheel....some one have any insight on what the problem may be????
hapyspaz
Austin
Look for a nail, screw, or something sticky stuck in the tread. Inspect the tire carefully. Check your air pressure.
Does it increase with speed?
Put the back end on jack stands if you dont see anything, put it in neutral, spin the rear wheels by hand and listen.
DISCLAIMER: DO NOT LIFT THE BACK OF THE VEHICLE WITHOUT SECURING THE FRONT TIRES! DO NOT START THE VEHICLE WITH THE REAR OF THE VEHICLE IN THE AIR UNLESS YOU HAVE SOMEONE IN THE VEHICLE! WE DO NOT WANT YOUR NEXT POST TO BE ABOUT ROLLING YOUR TAHOE THROUGH YOUR GARAGE!
Carlos123
