Climate control switch
5strmtrp
Do any of you guys have issues with the fan speed switch on your trucks? Mine seems to only work when the dial is just past 1/2 speed and up.
My ole Pickemuptruk and Coprice had “control board” at the bottom of the air box under the dash.
PG01
Up here to the right
Should still have a resistor there, just electronic now.
5strmtrp
5strmtrp
Damn
You guys are fast!! That’s what I was talking about, trucks with my wife today, will take a look tomorrow and order if it tests out it’s bad.
Thank you!
GreyStone
Mine feels very similar to what you describe - at the lower settings the airflow is almost undetectable, but blows great at higher settings. Might just be the nature of the beast.
5strmtrp
5strmtrp
I would agree with you if my trick did the same thing since I bought it. It has thou stopped working at anything lower than 3/4’s on the dial now.
As soon as the part comes in and I can change it out I’ll post an update.
1stYukonXL
