00YukonSLT5.3Rwd
Obviously I have a 2000 Yukon 5.3 2wd. At 155k I lost 2nd gear and had trans rebuilt. Also they installed a hd torque converter. About 6 months ago I started developing a clunk. Over speee bumps, now and then when I let off brakes at a stop sign. Backing out of my driveway does it. I serviced the rear, checked the ujoints, replaced shocks and rear sway bar links. I read on a post the yolk is the cause or transfer case. I don't have a transfer case. If I pull the driveshaft and grease the shaft will that be a fix or do I need a new drive shaft? Or is it something else? I just dont want to keep throwing money into it and still have the same problem.
