Code help. U0422-71
scoobydont
Thanks in advance, need some help diagnosing a code. U0422-71 Invalid Data Received From Body Control Module - Actuator Stuck.
Welcome to the Forum from NH.
Pics of the truck, please.
Some items to review and work through.....
The code U0422-71 indicates an invalid data stream from the Body Control Module (BCM) and is related to a stuck actuator. This usually suggests an issue with communication between the BCM and the actuator, potentially due to wiring problems, BCM faults, or faulty sensors.
Here's a breakdown of the likely causes:
  • Wiring Problems: Damaged or poorly connected wiring between the BCM and the actuator can cause the invalid data stream.
  • BCM Fault: The BCM itself might be faulty or experiencing a software issue.
  • Faulty Sensors: Sensors providing data to the BCM could be sending incorrect information.
  • Actuator Failure: The actuator itself might be stuck, preventing it from receiving or transmitting the correct data.
Troubleshooting Steps:
  1. Inspect Wiring: Carefully check the wiring harness and connectors between the BCM and the actuator for damage, corrosion, or loose connections.
  2. Check BCM: If wiring is good, the BCM might need to be replaced or reprogrammed.
  3. Test Sensors: Check the sensors providing data to the BCM for functionality.
  4. Actuator Inspection: If wiring and BCM are good, the actuator itself might need to be replaced.
  5. Battery and Alternator: Low battery voltage can also cause communication problems, so ensure your battery and alternator are functioning correctly.
BKraft
