Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Could the MAP sensor going bad shut my fuel off? Is there a valve in the fuel lines between the fuel filter and the pump? I have a 2000 yukon xl2500 with 2 fuel tanks.
My evap. sensor was throwing P0452and i ended up putting a new fuel pump in with a new sensor.I replaced the pump because the fuel level arm assy fell off. so as the new Ac delco pump had a evap. sensor i killed two birds with one stone.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
