Cold then Hot
aircrewjake
I have a 04 Chevy Tahoe. When driving my truck will go from full cold to full hot with not input from myself. I have the dual climate control heater switch. I think it may be a solenoid that directs flow into the heater core. But I am not entirly sure. When I stop turn the car off and turn it back on it works in cold again. Has anyone heard of this and do you know what is causing if?
Yang1815
Hmmm I've had similar problem where it's all heat after the battery's disconnected. I'd disconnect and re-connect just to see if it resets.
Coolwhip69el
