Conductor’s Special 232 Train Horn Kit
01Konvict
Boats n Hoes
Raleigh/SML
I don't like the way those mount in my opinion. I would mount them like I had it with all four horns mounted vertical with horn end down. To mount this way use some metal plate and bend it to stack in all four horns. The longest horn will sit just past the chrome portion hidden by the lower plastic bumper. Remove the rubber separator part between bumper and radiator to allow access. I know when I mounted this way you could get sound reflection off the ground. Plus side to mounting this way is nothing can fall into the horns and damage the diaphragms.
Pockets
West Ga
There would still have to be some sort of angle on the 2 longest horns. Sure you can do that on an obs but not on a 15+... we have a major bumper support that's right in the way. I'm not into cutting that out
LA Rodz
O.C.
Eric: What parts did you order and from where...obvious
next mod
01Konvict
Boats n Hoes
Raleigh/SML
For my 2011 Denali the tanks are mounted in place of the spare tire and I used some sheet metal to mount the compressor vertical. Also used a little piece of sheet metal to mount one end of the 2 gallon tank to frame crossmember. One end of the tank mounted directly to spare tire frame brace. The compressor is mounted to frame right near the exhaust pipe and heat shield. I used a old fan belt cut into pieces for rubber insulation to prevent vibration against frame. I will upload some pictures of the tanks and compressor. For the horns I mounted them on some metal strips then screwed that onto the front plastic skidplate that covers the front diff area. The plate that comes down from the radiator to lower frame brace. I didn't want them sideways but I was stuck to that area without stuffing them inside the front bumper in weird places. Best I could come up with until I find room for a K5LA hahaha!
Pockets
West Ga
Find somewhere else to mount your tanks and put them in the spare location. That's how I had to do it on my truck.
chevync
chevync
North Carolina
I just pulled in the driveway, seen my cat, that bastard did a complete flip in the air and was diggin up dirt! lmao Love the horns!
Ericbennett82
