Constant Light on for wiper/fog lamp switch
Archer04
So I had lights out on the switches in my Dash, so I decided since they needed to be replaced I would upgrade to LED lights for the whole Dash, it is coming along nicely and taking my time to make sure I get it right.
When I upgraded the Wiper/Fog Lamp switch there was a light in the lower left corner of the switch that was on a different circuit in the card then the other two lights. I tested for positive negative connection and made the LED with a 470 ohm resistor. When I plugged the card in to test if the lights would come on. The light in the lower left came on immediately without the Headlight switch being on. I tested the wire for the positive side of the LED and found with no power on in the vehicle it had a constant 0.4 volts running to it at all times. So my question is, is this correct or do I have a wiring issue to chase down?
Any information would be greatly appreciated. Oh and when I put the entire switch back together I found that the light emits through a tiny hole just left of the Fog Lamp switch.
BeenChevy
Minnesota
Do the fogs still work? If yes, you grounded the switches light. If no, check the fog relay in the under-hood fuse box. I don't think it swaps identically with the hi beam or low but you can still test to see if it's functional.
RepublicanRebel
