So I messed up....when I was changing my plugs, what I believe is the coolant temp sensor wire fell apart. I went to unplug it because it was in the way of that first drivers side plug. The retaining peice broke first then the whole harness just fell apart. I'm not getting any reading to the cluster for the coolant temp and shes running rough. Mostly just hard starting. Attached pic of said sensor just incase I'm wrong. Question 1: Can I replace the connector
Question 2: can I drive this in the mean time without it overheating? My cooling system is otherwise fine.
Sent from my SM-G950U using Tapatalk
