While I'm replacing the engine should these sensors be replaced or just reuse the Originals?
I definitely don't want to go back and replace the old crank sensor behind the starter a few thousand miles down the road, so though it wise to replace them all now.
Will a relearn need to be done regardless as it is a different block, crank, and cam or luck of the draw that it all matches up?
