cranked hoe shock question
felskee
i have a cranked 1.5-2.5 99 hoe and i need to find longer shocks. can someone help??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
The swing in the control arm is still only going to swing so far as far as the travel stops are concerned so why bother. Unless they are like Monroe sensatracs or something similar.
noJeepshere
Bountyfull, Utahrd
Because people don't understand what cranking your torsion bars actually does.
Burn. Stock application shocks will work just fine for you. I put Rancho 5100's on mine because I go off-road a lot, but if mine weren't cranked/lifted I'd have put the Monroe sensa-tracs on the back. Monroe doesn't make self-leveling shocks for the front for our aplication.
noJeepshere
Bountyfull, Utahrd
Sorry, mybad, looked again at the reciept, they're 5000's. Part numbers are:
Front-RS5152
Rear-RS5190
In my opinion, the front shocks are a little soft for my taste, the front end wallows a bit on the freeway, but on bumpy roads and rough tracks, they're spot on. I do prefer a stiff ride though.
mhessick
