Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
i recently installed a touch screen radio, capacitor, amp, and some subs but now I've noticed that my cruise control is no longer working.. and ideas why? TIA
Hi, The first thing you need to do is run it on the scan tool (Tech II) and check for codes. Certain codes set will defeat the cruise control. Correct any faults found. If that does not fix the CC, backtrack your installation and check all connections and wires for breaks, loose terminals, etc.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
