We have any Nitrous pros in here?
I got to thinkin about setting up a single stage wet 100-150 kit last night, but want it (IF I go through with it.) completely hidden.
Need somewhere to hide the bottle or bottles..
Use a progressive controller based on TPS, so theres none of that tell tale sudden hit a typical WOT switch has.
With arming, purge and bottle switchs mounted inside the center console along the bottom of the drivers side to conceal them aswell as my master arm switch mounted inside my cubby below the radio. Figure this would be nice and safe as no one but me would know how to use the system.
hiding the lines along OEM fuel lines then up above trans to back of motor and under the intake to a TB plate.
I found a TB plate with mini solenoids mounted directly to it in such a way that they cannot be seen from front top of motor. But cannot find it now. Any ideas?
Looking for any and all information here, as I am a Nitrous dummy.
