CV axels
greenhornet
Ontario,Canada
Can the front CV axles be removed and the vehicle driven safely,also remove drive shaft to the front diff.I need help as i am going on a long trip wed. and no one can fix the front diff soon enough.Help.
Gzes
the drifting 2dr
Wichita tx
They are on for a reason. If they are messed up get em fixed if not keep em on. Better safe then sorry.... O and dont cheap out because if yoy do you wilk regret it on a road trip. Trust me
purple 'hoe
Green Bay, Wisconsin
What's wrong with your front differential that you can't fix it right now? I'd just replace the CV shafts and call it good. You can't drive it with the CV shafts off really. You're going to do more harm that good.
If it's just you need CV shafts, then go to a parts store and replace them. It took me a hour or so of my time laying on the ground to replace one side on a NBS 1500. Nothing complicated at all either.
G
greenhornet
Ontario,Canada
The CV axles are fine but the diff output bearings are growling and i was hoping that by removing the axles would buy some time till i got back and had the diff repaired.
alc5m
if you remove the shafts youre going to destoy your hubs
we dropped the front diff on my brothers colorado and pulled the shafts as well obviously and its gone thru 2 sets of wheel bearings already without the shafts in it
my suggestion would be to get it fixed right, and maybe find a different vehicle for your trip
G
greenhornet
Ontario,Canada
Well here's an update ,I pulled the CV axles and removed the splined stub off of the CV axle that goes in the wheel and re installed the stub and re torqued the axle nut to the proper setting as per the Transmission shop who said it would work . When i get back i will bring it in to b rebuilt.Also removed the input drive shaft.Now it is like a 2WD. It needs the stubs in to keep the preload in the bearings.Thanks for your help.
2009TahoeLT
