d r l question
diesel1114
queens nyc
hi guys has anyone tried to wire the drl lights to come one with the fog lights or run with the low beams ? if so how can this be done Ny help is greatly apprecitated:Handshake:
john nyc
chauncey0337
MLT, WA
Easy, just splice them into the lights you want them to come on with. Or run them in parallel with the lows or fogs with a diode and you can have them function as normal and have them come on with lows of fogs.
D
diesel1114
queens nyc
thanks for the info , how can i do tat exactly im having like a brain fart ? im trying to picture exaclty how lol
thanks
john nyc:sleepy10:
chauncey0337
MLT, WA
Which one do you want to do? Do you still want them to function like normal and come on with the lows or fogs?
D
diesel1114
queens nyc
i actually have them deactivated with both fuse and realy pulled so i want them to just come on with low beams
john
chauncey0337
MLT, WA
I believe you can do that from the fuse box by using a diode from low relay to drl relay but I forget which pins to jump. Let me search for it or someone who knows might chime in.
D
diesel1114
queens nyc
thanks for the info and help you have been great and i apprecite it alot , only other question i have is that now when i do this will the drl only come on when the low beams are on ? thats actually what i want not to have them on and only come on when low;s or all 4 headlights are on
chauncey0337
MLT, WA
Now that I think about it, since you want to disable your drl's and have them on with lows, it might just be easier to do what I first suggested. Cut the drl wires, enough to reach to the lows, and splice them into the lows. Positive of drl to positive of low beam and negative of drl to negative of low beam, and repeat on other side. Then tape the ends of the original drl wires so they don't short on ground just in case you put the relay back in. Sorry for the run around.
mhessick
