Dash Lights
JochenWoern
Sacramento, CA
Is the Dimmer wheel as well as the symbols to the right of it (I think the top resembles a light, the bottom is the same symbol as the cruise control) suppose to light up at night?
On my truck, all that illuminates are the Head Light Switch, the Dome Light override symbol (below the head light switch) and the rear wiper switch (including it's symbols) to the right of the dimmer wheel.
If the dimmer wheel and it's symbols are suppose to light up, any tips as in HOW TO remove this part on the dash and how to replace the bulb?
Many thanks.
Rivieraracing
You seem to be in the same spot I was a while back, once you find one burnt out bulb you start looking all over the truck for any others!! Glad I replaced all of mine, bugged me pretty bad when I noticed all of them!! lol
JochenWoern
JochenWoern
Sacramento, CA
Yep, I am pretty **** with my stuff and want to make sure ALL works as it should.
Now that I know that the dimmer wheel is not lighting up, I am good with exception of the two (2) bottom Steering wheel switches which need replacement due to the bulbs being burnt out.
JochenWoern
JochenWoern
Sacramento, CA
Did you notice if you seat memory switch lights up?
Unfortunately, my truck does NOT have the memory seat option. :(
(Which I hate, as of course every time the Mrs. drives the truck, I need to fiddle fart around to get things back where I like them and she obviously has the same issue when she gets in my truck. But, .............. It Is What It Is!)
DCarl019
