Dash Paint
wma4553
I have a 1999 Tahoe with tan interior and the dash is good except the front trim piece (I think it's called the bezel), has begun to fade. Does anyone know of a source for some touch up spray paint that would match. Thanks
tlamot01
Missouri
Best bet to color match is to pull out the trim cover or maybe the glove box and take it into an auto paint retailer/shop in your area. They should have the computer matching system along with the setup to create aerosol spray cans of the color matched paint. The most important thing is that they will require a sample, which is where bringing in your dash piece comes from.
bigfeet
Barrington, RI
There are more than a few companys that make vinyl/plastic paint specifically for this job. They have all of the GM colors available. Your interior color code is in your glove box. SEM makes a great product. If you want an easier route, Duplicolor vinyl/fabric spray has a couple tan colors that match good too. This can be found at pep boys, etc. There is no need to have a color mixed special because companys like SEM, etc., have the exact colors/codes already in a can. If you google GM plastic paint you will have your pick of brands to buy, all coded to your exact color.
W
wma4553
SEM paint on Ebay
Thanks Guys,
I just found what I needed on Ebay, a SEM spray can of light neutral for about $15.00 including shipping. Thanks again for you help.
pistolpetem9
