Dash paint
Repo503
Anyone know where to get grey paint that matches the denali dash? (the dic surrounds and ashtray cover). Part #s would be really helpful. My damn dogs like to try to sit next to me when I drive and they've scratched it up pretty good.
NJ04HOE
Paterson, NJ
I don't have a part # but I did get some mixed at a auto body supply store I found that wasn't too far from me. I used it when I put a monitor in my console but when I went to get more they told me that they might not be able to get a "perfect match" to the color I brought the first time.
Check and see if you can find a auto body supply store in your area and take a piece in and see if they can try to match it for you.
DarkTahoe00
IN
Check out SEM paints they got interior paint that'll match or pretty damn close,check a local upholster shop around you they should be able to get it for you or check SEM's website.
Rivieraracing
SEM paint is awesome for what you are after, a little spendy for a can but well worth it!
yukonjacks
A Vegitative State
The Confluence
Look for a SEM dealer in your area. Its called Color Coat, its a flex coating, the SEM Shale # is 15793, the grey isnt an exact match, I did the inside part of my Bezel with Cherokee Black SEM# 38563. The greys are up to you Light Charcoal SEM#39583 andMedium Grey SEM# 15393. They can do an exact color match which is $25 and they will mix and put in an aerasol can for $18+ I found that the paint doent lay as good nor does the aerasol last. You will also need scuff and clean SEM#38338, Plastic Prep SEM# 38353 and Plastic Adhesion Promotor SEM# 39863. Now you can by all this and be thoroughly pissed by the time you start actually painting, OR get the scuff and clean, get some scuff pads, and plenty of soap and water. Make sure its clean as heck, get some grey primer lightly prime it let it dry completely. Then in light coats paint your dash
GOOD LUCK
Plastic is a pain
Narco
Atlanta
i need some too. tan. there are 3 or 4 small flecks of color missinf from the top of the dashboard. total area is smaller than a quarter.
showtime1k
any body get info on the part number sem. i got a 2002 denali with shale pewter interior. whats the sem color for that. i called them and they told me they had 3. med dk pewter, med dk pewter2, and med pewter???
pistolpetem9
