daytime running lights
02_denali_guy
daytime running lights not workin. worked when i bought the truck, changed out bulbs for leds, one worked, now both dont work. any ideas?
chip
Tampa
Check your wiring. Leds must be hooked up correctly to operate correctly. If that doesn't work, check fuses and relays.
02_denali_guy
ive checked the fuses and relays and they still good. i noticed the inside of both plugs are black, wonder if i could have fried the plus sumhow?
chip
Tampa
Mine look like that too. I think it's just cheap materials. Have you tested the wires for juice yet? If not, get a DMM or a test light and see where you're losing juice.
A623Z
Phoenix, AZ
LED's don't last in tahoe's due to the voltage spikes, try swapping out with 4114 bulbs so they can take the spikes
chip
Tampa
That explains so much, about other things. What do you know about these voltage spikes?
Champ74
