JMNoles
- Joined
- Sep 7, 2016
- Posts
- 10
- Reaction score
- 16
I own a 2005 so I don't have this problem, but I swear every 2007 and up Tahoe has a burnt out running light. Is this a common issue? Or am I the only one that sees this?
Hey 2004 Denali here, I have one with a burnt out DL light! I'm lazy what bulb number do I need?? And you pull the retaining pins (don't know what they are called) and the lower lights just pull straight out??
Thanks, I'll double check on that before just slapping a new bulb in there!Usually, it's not your bulb, it's the socket. Replace the bulb and it will keep doing the same thing. Most of them are because the socket looks burnt and is...
