DDM tuning hids
Richi5280
Richi5280
oklahoma
Aligning is goofy on aftermarket... the screw furthest to the outside finder is up/down and screw to the inside is left/right. But it is goofy because with my expierience, I go up and adjust and then do the left or right. If you go left or right to far then th sucker starts going up!
The way I have always adjusted HID's on the vehicles I have done....is by glare. Find a dark road at night and set out two reflectors on the road and adjust your glo. That has worked best for me. Damn if you put some tape on the garage door and get them suckers aligned, go drive it at night and them suckers are all kiddywampus!
When aligning my lights what exact screws are you talking about? I have no idea which ones??
oakrdrs187
Coachella,CA
There is nothing better than OEM projector retrofit. Reflector lights suck at putting light out on the road period, and ebay projectors design for halogen bulbs suck too.
Whoever wants more info on what superior lighting is really about.
Go to hidplanet.com and do a little homework, within 15 minutes of read some FAQs your views on lighting will be changed.
Direct link: http://www.hidplanet.com/forums/content.php?4-Everything-you-ever-wanted-to-know-about-HID-bulbs.&
My plans for my HOE will be to run quad bi-xenon projectors retrofit to the OEM housings. Fitted with 55w 5000k lights.
Yuko04
"SquareBODluvr"
MN
When you open your hood look down at your lights, your adjustment screws are right there. look where you actually put you bulb in....them adjustment screws are right ther in that bracket. if it were a snake...it come out and bite cha!
hidpositive
im about to order up my hid's from ddm (and do the hi6 mod) but was curious to see if any of you guys have issues with foglight housings melting from the heat? I want to run 55w 6k in my headlights and was hoping to run the same for my foglights..
-Gary
chauncey0337
MLT, WA
-Gary
55w will probably melt your stock fogs.
hidpositive
thats what i was thinking too, my buddy has the same (55w 6k) ddm hid's in his 03 cobra and his foglight housings started to melt just a little bit. I would like to avoid anything of the sort.
The whole electrical idea is what i know the least of in any vehicle. from what i read i think if I run 55w (headlight) and 35w (fogs) and 6k bulbs in both the headlights will still be brighter then the fogs right?..So should i run like 35w 7k hid's in the foglights? to even them both out..
-Gary
chauncey0337
MLT, WA
I would go 6000k for both but I've heard the higher wattage washes out some of the color so if anything go 55w 6000k for lows and 35w 5000k for fogs.
oakrdrs187
Coachella,CA
This.
Mine melted the shield in-front of the bulb. So I opened them and took it out, Then re-adjusted my fogs lower, haven't been flashed by oncoming yet....
I'm running 55w 6000k heads and fogs.
---------- Post added at 06:11 PM ---------- Previous post was at 06:03 PM ----------
Oh I hear ya! definetly takin the advice. I just ordered 8 new bulbs about an hour ago. 4 55w 9006 6k and 4 55w 880 6k. That will take care of the Saturn& the Yukon...If i like them, i guess i start swapping out my whole fleet of toys headlights. Yeah thanks guys...you just hit my wallet LOL!
So you know, since you had a misunderstanding about the Kelvin rating, It's not the bulbs that are 55w, it's the ballast. Since you already have 55w ballasts you will be fine. DDMTuning sells only one bulb that can handle both 35w and 55w, it just depends which ballast you connect it to. So the 6000k bulbs you ordered will be bluer if connected to 35w and on the whiter side if connected to 55w.
mharders
Just outside of Seattle
So I have the ddm 35w 6000k in my lows and want them a little brighter so I just need to buy a 55w ballast and use my existing bulbs and then move my 35w ballast down to my fogs and by 880 bulbs? So basically just need to buy a 55w 5000k 880 for my fogs and the lights are interchangeable between ballasts?
Yuko04
"SquareBODluvr"
MN
This.
I've never had any melting issues in my Yukon or my Saturn Vue or the Grand Am. All 3 vehicles have 55w 10k in heads and fogs( which for some reason I have to swictch them all out to 6k now with this new wonderful info...but anyways). Saturn and GrandAm have 10 hrs of night driving a week on them and the have not melted. Maybe it has somethin to do with our -30 windchills!
super_kev
