death wobble
swab
okie
around 35 mph i get a death wobble from hell. im 99.9% sure its from the passenger front and its real bad when im braking. the last thing i remember doing to my truck was a brake job but everything was tight. any suggestions? im doing lower bjs/passenger hub during winter break. and im also sure its not the hub because when my drivers side went (unexpectedly at that) my wheel didnt shake, it just came off. any suggestions would be much appreciated.
WH0DAMAN
I sure as heck woudnt drive it until you figure it out. I would agree w/ blueflamed that it is a warped Rotor.
JKmotorsports
Austin, TX
So it happens while cruising and braking? Really bad ball joints can cause the wheel to wobble both during cruising and braking. Most of the time, warped rotors cause vibration only during braking, unless the lateral runout is really bad, in which case will cause a bad shimmy while cruising also.
Definitely check the ball joints first, cause if they fail while your driving, could end up being disasterous.
ravingmadman
Chief Knuckle Buster
Greater Seattle
Hey, we need to make an "effing wheel fell off while I was driving" or "Rocked it till the wheels fell off" club. lol
Questions- Do you feel it in the wheel AND the pedal, or just the wheel? If the rotor is warped, you should feel a good pulse in your brake pedal. If you don't feel it in the brake pedal, go for steering/suspension. My driver's side hub went before the passenger, but I replaced both at the same time. If you feel it in the brake, it still could be ball joints or the hub assembly, so don't rule them out.
Is this a 4x4?
S
swab
okie
yeah, only the wheel shakes the brake pedal doesnt pulse. it is 4x4 but the hub seems to be fine. and if you want to start a "rock it till the wheels fall off" club ill join lol.
96ProCompTahoe
IN
made sure you don't have a bent wheel? and the lugs are tight? it sounds stupid, but both could do the same thing.
had the lug one happen on a previous vehicle... caught it before it did any damage thankfully.
riviera rider
i have the EXACT same problem it started last monday, if you figure it out PLEASE let me know. my friend works at firestone and has no idea what its coming from nor does anyone else there. they said it could be a drive train problem. however mine doesnt do it all the time only if you accelerate hard, if you ease up it drives fine... im so confused!!! mines a 99 4x4
im thinking of taking it to a trans shop but all they are gonna say is that the trans if jacked and want like 2000$ to rebuild it. ill sell it b4 i do that! lol
blanchard7684
