Yes heat gun/hair dryer, adhesive remover and wax. As for the moldings, I can't help you with that. For the badges use heat gun to preheat then use a flat tip screwdriver and place it on a corner of the badge ensuring it doesn't touch the truck and, apply lifting pressure while holding the heat gun about 6 inches away from the back of the badges and you continue to peel away the badges. Some folks have prefered to use dental floss for the removal tool but IMO it's too much of a PITA, you'll have to figure out which is easier for you.
