Delema
steven13608
:emotions122:
ok maybe some one can help me out.... i swapped out my painted exterior door handles for some black ones, i tested out all the doors as i replaced them to make sure they still worked. and the only door that doesn't work now is the back passenger door (RR). for some reason i cant open it from the outside or the inside. does anyone know what i can do to fix this, or at least figure a way i can open the door so i can get to the handle??
fiatdale
Houstons Best
Houston
You must not have connected the cable to the trim panel handle or connected the rod for the outside handle. If you can, very carefully pull back the top of the trim panel just enough to pull the weatherstrip gasket up and out.
Then take a long screwdriver and locate the latch. You'll see an orange clip attached to the latch. Use the screwdriver to push down on that clip and the door will open. Then you can remove the trim panel completely and connect all your items.
lnzmcqueen0428
