Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
i had the same question when i got my hids for my fogs. just cut off the male ends. use a loop hole for the black wire and ground it somewhere. the red needs to be run through the existing fog light setup, so you can literally just tie it in where the halogen bulb used to be.
you got the 880? well i guess this is the same job ill be doing in a week or so then.what color did you get? i got 8000k 55w lows and 8000k 35w fogs on the way.
ya i read it in FFs thread too. mine will be another week probally. a few pics of your install would help me as ill probally do it the same way as you.
Generally 880's dont come with the actual plug. Those little metal tabs will fit in to the factory harness plug though. As mentioned before grind them down a little and plug em in. No worries, I did it in my Firebird and in other cars. Or, you can search online for the connector.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
