Denali oem projector fitment on base yukon
yukon1024
Hi, i was reading some threads and by the looks of it i can put denali oem projector headlights on my 02 yukon slt. I'm going this route cuz i had halo projectors before and didn't like the output and don't want to do a retrofit right now so i'm guessing the denali ones have a good output. I know u need to do some mods cuz of the 9005 bulb but im planning on putting hids so i just buy the 9005 kit. Does anyone know if the ones they sell on ebay if their oem? Here is the link http://m.ebay.com/itm/GMC-Sierra-De...-Headlights-/271669507220?nav=WATCHING_ACTIVE
Or
http://m.ebay.com/itm/Headlights-He...ruck-Denali-/371025553921?nav=WATCHING_ACTIVE
fiatdale
Houstons Best
Houston
Neither one is OEM in those links you sent. They will fit just fine, decent output but no match to a retro.
If you wanted OEM, I think they run about 250/ea.
Y
yukon1024
Damn 500 im better of buying a pair clear headlights and morimoto mini h1 7.0 both for about 300 or less n better output
fiatdale
Houstons Best
Houston
I think they make adapter plates for morimoto in the stock Denali housings. If those housings you found are DEPO they are decent quality. Just keep them clean.
subieworx
I just did these in my 03 Denali headlights a couple weeks ago.
https://www.theretrofitsource.com/c...i-xenon-morimoto-mini-d2s-4-0-projectors.html
I had HID bulbs in the factory denali projectors before that and the light output was terrible. This retorfit kit is amazing. OVerall larger than the mini H1 kit with a better light output. I couldn't be happier.
THe retrofit wasn't too bad either. Took about two hours start to finish. All I had to do was cut the factory projector mount a bit to fit this larger projector. Then sealed the back with some rtv. Working great so far.
