dthomas2003
- Joined
- Jun 27, 2012
- Posts
- 4
- Reaction score
- 0
When turned right or left 100% of the way, steering wheel fully turned, it makes a rubbing noise combined with a feeling as if the front tires are skipping across the pavement. This occurs when making U-Turns, or tight slow turns in general.
-After driving for a long period of time straight on the highway, getting off the freeway and making turns (into a gas station, etc.) it makes the same loud rubbing noise combined with the front tire skipping feeling. It then proceeds to go away once I straighten the wheel out.[QUOTE]
My 2001 Denali with 128000 is doing the same thing. If I drive 30 miles or over then turn the frontend it makes that clunking and tire skipping noise. It's got to be heat related. Iv'e read and checked TSB#06-08-61-003 Body mount Insulator. Iv'e checked the torsion bars. Iv'e installed both CV axles. Iv'e changed front diff fluid. Iv'e checked the I-Shaft. I'm looking for a AWD or electrical issue I guess. I hope someone has a answer. I hope to resolve this before it does some damage. Member (NorCal Nali) had the same problem 7 months ago and I'm hoping someone has figured it out.
