Denso O2 sensors
blondie70
I installed 2 upstream Denso sensors...no mention of programming.....but....after about an 80 mile run, I am getting a CEL. Code is P0171. My cheapo tool says "fuel trim lean".
Report on my switching the Denso sensors left to right......truck now throwing P013E (1-3) STORED....think it's saying it is the secondary sensor ???.
Makes no sense to me.....any info on this appreciated....thanks.
ps...the GM sensors have not arrived yet.+
below are the Denso sensors: (Rock Auto)
that are throwing the codes........
2012 CHEVROLET TAHOE 5.3L V8
DENSO
2344668 (234-4668) Oxygen (O2) Sensor
$ 28.99
$ 0.00
$ 57.98
B
blondie70
Still got this code. Think it's for the back o2 sensor for the cat ?
Trey Hardy
Eastern North Carolina
DENSO
$ 28.99
$ 0.00
$ 57.98
I had to return my densos because they were doing the same thing I think the only option I had at the time was a Bosch sensor from the parts store and I never had a issue since
Trey Hardy
DENSO
$ 28.99
$ 0.00
$ 57.98
Ps the rear 02s don’t do much I actually delete them out of all my trucks when I have them tuned and put headers and exhaust on them so it’s one less thing to worry about…
Fless
Super Moderator
Elev 5,280
That's a driver's side, post CAT sensor code. I suspect that your P0171 code is causing this other code, so I'd ignore it until you get the upstream ones working properly; either that or fix what else is causing the lean code.
For the lean code, check for intake manifold and exhaust manifold and pre-cat pipe leaks leaks on the driver's side, since it's not indicating on the passenger side.
Would you have short- and long-term fuel trims to share, at idle and at 2000 rpm or so?
B
blondie70
No fuel trims as I am not well versed in what my scanner can do. It is an Innova 3040RS v1
But
My new O2 sensors OEM came in today. They are also Denso, but a different #.
I am gonna put them on, clear the code, and see what happens. May be o k then.
I will report resullts back here after running some.
Thank you gents for your advice on this.
B
blondie70
But
All ok now with the new OEM sensors...no CEL. I now have a lot of $$$ in sensors. Frankly... I screwed up by ordering non OEM the first time.
yampa
