DIC question: Tire pressure?
Martinjmpr
Littleton, Co
So I've now driven two Suburbans, an '04 and an '05. The '04 was much nicer, but when I drove the '05 I noticed that the Driver Information Center (DIC) would display the pressure of each tire, which I thought was really cool. Then driving the nicer '04 I couldn't pull up that function on the DIC. Both were LT package so I'm thinking the ability to monitor each tire separately wasn't added until 2005, yes?
Also, on the ones where the TPMS monitors each tire separately, how do tire rotations work? Do you need to swap sensors when rotating tires or does it somehow "know" (maybe by "position sensing") where each tire is?
This isn't a dealbreaker - looks like I will likely get the '04 just because of the lower miles and significantly better overall condition. But I was curious as I did like the idea of being able to monitor all 4 tires separately.
treehan77
TYF Fiend
Crestview, FL
There is a procedure to teach the computer which position each sensor is in. Mentioned numerous times in here. Or some shops will use a machine to do it. Walmart actually did mine surprisingly for free
Martinjmpr
Martinjmpr
Littleton, Co
So am I right that the individual tire monitor feature is not something an '04 would have had?
QUYHMK
