Did I pay too much ?
playadude
Front Shocks - $492 parts, $342 labor
Replace spark plugs and wires $224 parts $189 labor
Replace rear shocks $296 parts $119 labor
Replace Lower Ball Joints $296 parts $594 labor
I think I paid high retail for the service.
The shop is excellent and the Tahoe drives like new.
(2011 127k miles)
Not much I can do about it at this point.
Thank you :)
Big Mama
Virginia
There’s a markup on the parts of usually around 70-100% the labor rate looks to be about $100 per hour. They have a time guide for each job say the front shocks is 1.5 hours times their rate the one that’s a little fishy is the ball joints and shocks as they’d do those together but they billed separately but if you’re happy with the work I wouldn’t worry about that. Piece of mind is priceless
intheburbs
SE MI
If you're happy with the shop, that's the most important thing. But those prices do seem a tad high.
I bought 4 new Bilstein 4600s for my Suburban online, and paid a shop $150 (Firestone) to install them.
And I just bought 4 new shocks for my Denali for $216 shipped, and installed them myself. Casual pace, took about three hours. $85 for an alignment at the local tire shop and I was done.
I also had a Goodyear replace three of my four ball joints on the Denali, and it was $500 for parts and labor. While I was under the front end doing the shocks, I inspected the ball joints, and they look good.
08HoeCD
I continue to be amazed at the rates shops get for completing simple jobs. Yes, I've paid them, and more than once.
On the other hand, I've done some things on my own and was surprised at how easily some low-tech jobs are to complete. I'm no mechanic, but if I can by swaybar end links for peanuts and install them in my garage, laying on my back without a lift, then how in the world can a shop charge $300 to do the same job with a lift and with impact wrenches? It must take them more time to raise and lower the vehicle on the lift than to swap the end links.
I remember that a Ford dealer wanted $775 to replace my radiator cooling fan assembly. That did not sound right to me, so I bought the part from RockAuto.com for under $230 including expedited shipping, received it in two days, and installed it in my office parking lot using only a crescent wrench (as I recall) and made the swap in less than 30 minutes. lol
I'm all for a service provider making a profit, but the huge dollars put people off.
adventurenali92
Big Bear Lake, ca
Parts and labor on the rear shocks so about right. Not too bad on that. Other things seem pretty high. But like they said above piece of mind is priceless! If the work is done and you have it checked off the list and don’t need to worry about it, that’s worth it.
Derick
Indy Suburbs
Ouch.
I cant speak specifically to the Tahoe parts but I paid the following for suspension parts recently. I bought premium parts and did the labor myself.
Shocks all the way around were 66 bucks each. Two bolts each to replace. Fronts were stupid easy, rear wasnt hard just needed an extension. Billsteins.
Lower balls are about 30 bucks for the HD Mevotech TTX joints.
Plugs and wires are about 50 bucks for ac Delco plugs. And about 60 for the new wire set.
So, in my opinion, that's all highway robbery. However you're paying for the convenience factor. How much is it worth to you NOT to have to do your own work? That's subjective.. From my perspective, I'll save the cash and do it myself. Alternatively buy your parts at rock auto and carry them to the mechanic. Save some coin that way.
That's why they're called "Stealerships".
Ouch.
Alot of mechanics won't install owner supplied parts.
Derick
Indy Suburbs
Time to find a new one at that point. My mechanic has never had an issue with it. Less he has to deal with from a warranty perspective in the future. My angle is, hey make your labor sure I get it. But don't eff me twice on both parts AND labor.
Kee Fuller
las vegas
They basically look at the mechanics book and see how many hours it says and charge you that. Even if they job takes way less time.
ericjvasil69
