Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Lil bit on the ceramic part of the plugs to seal the boot and keep it dry in there. Also between the module and distributor body if you are in there replacing that stuff.
I put it on the plug wire boots. Both ends. Keeps them from sticking. Also, on the distributor end I slide a small screwdriver between the boot and distributor to relieve the air pressure inside the boot. Sounds funny but I have had a couple pop out on occasion even when the wires are "clicked in".
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
