Difference between G80 and G65
Scottydoggs
NJ
G80 is a mech locker. one wheel slips even a tiny bit the other wheels locks it up like a spool racing rear end. when its locked up and your turning tight, you'll feel the turning side back wheel trying to spin and even feel the back end of the truck hop a bit at each rotation. might hear some clunking as well. all normal.
Someone please share what the difference is. Thanks.
G80 is the RPO for a locking differential. Exactly what type/style of locking differential varies between vehicles and generations. A big misunderstanding is that it's exclusive to the infamous Eaton Gov-Lock.
G65 is the RPO for manual level control, which, I think are the "Nivomat" shocks. Basically a mechanical ALC as opposed to the one that uses air sleeves and a compressor.
OR VietVet
OR VietVet
Multnomah Falls
Military
Willamette Valley
I should have been more clear. I know what the G80 is, because I have it on my Z71 and am sorry for not sharing that. I saw a G65 on a RWD Suburban I am thinking about buying and thought to compare the two. Manual level, huh? Gotta dig deeper to understand.
G80 is not in lieu of G65. With Chevrolet trucks and wagons the G80 was an option while Cadillac and GMC included it as standard equipment most of the time.
That Suburban has the Premium Smooth Ride Suspension, ZW7 and in that generation such includes the G65 Nivomat self-leveling shocks. The springs are softer on this suspension type as the shocks are not your average kind, they are smart but not electronically smart!
Fless
Super Moderator
Elev 5,280
The rear Nivomat shocks self adjust, but since they're manual adjust they need to do a little work before they actually restore ride height. So when weight is added or a trailer is hooked up it may take a block or two of driving for them to bring the rearend back up.
Provided, of course, they haven't been replaced with standard shocks (and hopefully stiffer springs).
Ha ha, I got away with saying "rearend" and "stiffer." ;)
OR VietVet
OR VietVet
Multnomah Falls
Military
Willamette Valley
Yeah, I thought it was a weird relation in his question, especially just the part about asking about the well-known G80 RPO.
I was giving the G80 as a comparison to the G65, not knowing what the G65 was, at all. Since the G80 RPO code is the letter G and two numbers, I referenced and compared to G65 again because of not knowing. I ask if I don't know or understand.
Papaskip
