Disable Service Suspension System DIC Message on 2010 Tahoe
applegate123
I have seen previous threads on how to disable the Service Suspension light/message on older Tahoes by pulling the RTD fuse under the hood. I could not find a similar fuse on my 2010. Does anyone know of a way to get rid of this message? I am guessing there is a problem with the compressor since sometimes it comes on and other times it does not. But it not worth fixing (over 120,000 miles), I just don't want to see the message. Is there a different fuse which is labeled differently which can be pulled?
Thank you!
Willizm
I'm not sure if there is a way to disable the SSS message. You could fix the issue by either replacing the compressor or a rear shock depending on which has failed. If the compressor is still working then it's probably a rear shock that is either blown or the sender has stopped communicating.
fiatdale
Houstons Best
Houston
Do a search, Ive posted many times about using a resistor on each of the shock locations to bypass it.
ADrake75
