DJM LCA/UCA alignment issues
Lit549
Those look like djm lowers.I had the same question and Tony said to NOT use the jounce stops..My truck doesn't drive well at all..
blurred
blurred
Puyallup, WA
I have the djm lcas and the stoppers are still installed as you can see. I have no issues and a smooth ride..
Now I need to figure out the upper issue...
Lit549
That spot looks to me to be more bracing than a place for the jounce to hit..The angle isnt right either.
blurred
blurred
Puyallup, WA
His suggestion was to use the DJM offset bushing, which I had.
I have since swapped out to the longest MMW upper control arm. This will work great for what I am planning to do in the future with the final drop since I plan to go a little lower.
So, with that said, I have the DJM upper control arms along with the regular and offset bushings if someone is interested in buying them. I haven't had time to clean them up though they only have about 5 months of use on them. I also haven't had the time to come up with a price either.
ToddYYC
