DJM lowering kit
iacordero
Minneapolis, MN
Hey everyone,
I had never considered lowering my Tahoe, but after joining the forum and looking at some of the trucks here, I officially have the bug. Mine is an '02 4x4 with 20in. '07 wheels. I don't plan on getting bigger wheels at any point and I'm not looking to scrape the road with the truck. It's still a family vehicle and needs to be comfortable. I just want to make it look a little more aggressive. I'm also not looking to spend a lot on a lowering kit - if I can't cross all of those items off the list for $300, I'd probably just not do it at all. With that being said, I'm sweet on DJM's 2/3 kit with torsion keys. Does anyone have experience or better suggestions? Do you think that it is worth doing with 20's?
Thanks in advance for your input.
iacordero
iacordero
Minneapolis, MN
I was under the impression that I couldn't do spindles on a 4x4 though... I don't know a ton about suspensions, I just know that if you hand me the parts and instructions, I will make it work.
Fosscore
Keep hitting Tony up. @NORCAL SS
He will dial you in. I have hit 3/5-6 kit and the ride, even if you are only doing th 2/3 will be so much better than stock. You will love the stance and the feel. Good luck.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
not true you can use the spindles. ALso 16 inch wheels wont work with spindles. ANother option is the djm front 2-3 inch a arms with new shocks. Excellent ride and for a little more you have new bushings/balljoints
05Single
afraid of the dark
Also not sure what trim your Tahoe is but I think the jdm 2/3 kit doesn't accommodate air ride. Could be wrong
Kingjackpot23
