DJM Trailing Arm Relocation Brackets
Status
Not open for further replies.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
For NBS and NNBS 2000 through 2014
Rear used Trailing Arm Relocation Brackets
These are a must have if you've lowered the rear of your SUV. The trailer arm brackets will re-align your axle in to the middle of your wheel well and fix your axle angle to the drive shaft. Includes all hardware (nuts/bolts) as well.
New the rear trailing arm relocation brackets are over $80.
I'll sell for $60 shipped.
HUMBL57
AC Guru
Phoenix, AZ
Contemplating these. Would I really need these trailing arm relocation brackets? Probably doing Tony's 2/3 kit in the spring and he includes the shock extenders it looks like.
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
They will move the rear end into the correct alignment (like it is before you lower it)
I'll have Tony come in here and explain better than I can...
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
shock extenders are totally different then the brackets.
extenders i use wiht 3 or more inches of drop. You will see the shock angle when going that low isnt the greatest. The extenders will push the shock back into a more verticle angle so they will function correctly.
the trailing arm relocators will fix the lower control arm angle
06escalade26
I'm years late but if you still sell the relocation bracket I would like to purchase one. I can be contacted 832-499-9191 Bruce and thanks
Status
Fernandocosme200
