I have a theory that I think I am going to try, looking to bounce it off of our mechanic minded members.
2006 Envoy Denali 5.3
Low miles (98k), cylinder 1 intermittent ticking, throws misfire code when ticking.
I have disabled the DOD/AFM in the PCM and now need to address the hardware, all research says the cam must be replaced with a non DOD cam due to the profile of the DOD lobes being incompatible with non DOD lifters. The common result seems to be low compression and poor idle if you try to leave the DOD cam in place and just replace the lifters with the non DOD lifters.
My theory on this is that the altered profile of the DOD lobes results in too little lift for the DOD cylinders when the non DOD lifters are installed; reducing the lift & duration on those cylinders which reduces the volume of air that is available for the compression stroke.
So I thought about trying to determine the overall length from the DOD roller to the tip of the pushrod, then buying custom length pushrods to match that distance with the non DOD lifters, then using those custom length pushrods on just the DOD cylinders with the new non DOD lifters.
It seems like this should restore the stock valve train geometry & performance of the engine when it is in V8 mode and eliminate removing the valley cover for oiling modifications (the tune disabled that) and allow the DOD cam to remain in the engine.
I am in the pleasant position of not needing this car right away so I don't mind a 2nd tear down if this doesn't work to replace the cam but I was wondering if anyone sees any obvious flaws to this idea that would cause me doubt to it's viability?
Thank you for your consideration!
