Does anyone make hose pliers large enough for the filler neck hose?
JamesLond
I have a set but none are big enough to fit this filler neck hose on my Yukon.
MassHoe04
Western MA
I haven't had any clamps in a spot so tight, I couldn't get to them with common tools. Channel locks have been the go-to and worked so far...
But the cable-actuated tools look like they might make things even easier. Maybe on my wish list.
J
JamesLond
Well I got it off. I got an oemtools hose remover from autozone and it seems the thickness of it helped me unstick it from the pipe (the smaller skinny ones I have bend under pressure). After that, I twisted the hose more loose and then I had to get myself in the right position, and then I had to push it off the pipe.
I still think it would be cool if someone made a hose puller for larger diameter hoses. The ones I have are super convenient.
2006Tahoe2WD
Silicon Valley
Nah get the cable actuated ones
I just replaced all the hoses... I should have picked up either the pliers or cable type clamp tool. I like the cable approach - which make do you recommend? I'm thinking of getting one for the next time - in 5 years or so. Thanks.
Nix409
