I know there are a few threads on dome lights but from what I can find their issues are they either stay on all the time or nothing works at all, can’t find anything similar to my issue.
When I open the door my front dome lights and front door courtesy lamps don’t come on. The rear cargo dome lamp and rear door courtesy lamps do come on and so do the lights under my side mirrors. The front dome lamps work if I turn them on manually. I have access to prodemand (or Mitchell, whatever you want to call it) but there are so many different options and their wording for certain things can be odd so if someone knows the correct diagram to look at that would be very helpful, or if you’ve heard of this issue what would cause some lights to work and others not to work?
My cluster lights don’t work either but I’ve narrowed that down to the dimmer switch and from what I can tell the front dome lamps aren’t tied into the dimmer switch. The override button also works normally for the lights that do come on and turns the headlights off pressing 4x.
