I have a 1999 Denali. I have put new heads, timing chains, plugs, wires, fuel pump and filter and a distributor. It has always started hard after sitting over night and here in Florida it's not cold in the morning. It has been getting worse so I change the fuel filter and that did not help. Now it will not start!
I have checked fuel pressure while cranking and it was 60lbs. and it holds pressure. It has spark but seems like it doen't even want to fire up. I have no idea where to look next. Would I have spark if the distributor module or the crank sensor where bad? I thought of fuel pressure regulator but it holds pressure. At my wits end. Any ideas. Also what is the difference with the new fuel injectors I have read about? But 1st things 1st lets get it started,
HELP PLEASE.
HELP PLEASE.
