Door locks won't go up
blazzinbird
Illinois
so when we use the key fob the door locks only go up a little bit. We have to use the keyon the drivers door then reach over and unlock the rest.
Is this a common problem?
Kenny D
Crosby, Tx
My passenger door doesn't go all the way down on mine with fob. If I try that door handle in that state of lock, it will pop the door but the latch catches and doesn't allow it to open.
08HoeCD
Sounds like you need a new lock actuator, as the motor in your existing one is burning out and won't consistently operate.
Kenny D
Crosby, Tx
On mine, the motor works fine. It moves up and down with the FOB it just doesn't go all the way down. It is like there is a catch in there somewhere when you manually lock it. I have yet to get off of my lazy butt and pull the door panel off and investigate.
chris08
I'm having a similar issue. Truck had no issues sat for 1 week and now the locks all work done. The first unlock and when you put in gear they all lock. You put in park they unlock like normal. But if you press the lock button again they all lock but driver front and rear do not unlock. Do this a few more times passenger front won't unlock. Turn the car off and on or drive a minute and they all work again. Can't figure out what this might be any ideas?
Dgrigg05
