Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
If you are shaving the doors on a daily driver, don't do it. They always fail. Make sure to install a manual pull so you can open the doors when it fails. The spring you just need to find a good, solid area to mount in the rocker panel usually in the corner of the door OPPOSITE of the door hinge area.
Keep the poppers oiled up for water displacement. Selonoids need to be mounted well. If you are using pipe hanger I always line it with good double side tape to avoid it loosening and shifting.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
