drive line vibes
big boy toy chevy
I had u joints replaced on my truck.....I dont think the drive shaft was replaced the same way it came out because there is a vibration in the drive line starting at 50mph that wasnt there b4.......can this damage the trans or rear end.......what can I do to correct the vibe .....rear drive shaft has been balanced and its still vibrating..
retorq
Kingman AZ
If it was balanced then your vibration is more then likely somewhere else. They only go in two ways, try changing it and see if that helps.
Jooseevh
