Drive Shaft problems
Nbak95
I Got a 1996 GMC Yukon 2 door running a 6 inch rough country suspension set up on her, with 35 inch toyo tires, the other day i took the truck to get tie rods put on it and my mechanic had the truck on the lift and noticed the rear drive shaft was only in the transfer case but maybe an inch or less and when he put the truck back down it didnt go back in much, so i got to looking at it and can see the constant wear before it was lifted and can see the after effect (its more shiny) so my question is has anyone found a cheap way to repair this without paying 500+ for a new drive shaft? maybe pulling one from an extended bed truck or something? Open to any suggestions and wondering if anyone else is having this problem
bowtiefreak
No Quarter
Near Philly
Take it to a driveline shop and get it lengthened. Should be under $150. Ask me how I know this.
I also do now run a Tom Woods CV shaft in the rear. But regardless, it can be lengthened
N
Nbak95
I live in po donk auburn alabama and there isn't a drive shaft shop anywhere close beside for Atlanta I have the old one in but at about 35 mph plus the truck shakes like a leaf my guess its bent and will end up forking $ out for a new one
mhessick
