Driver side window 2000 Tahoe
Cab Lizzard
Window goes down but will not go back up unless you shut off and pull key out of ignition. Then restart and it will go back up. Any ideas ?
All of the other windows work just fine.
If the window motor looks and or sounds pretty strong when rolling up or down the only possibly is the window switch because the left front and left rear have the same power source from RAP relay and the 25 amp circuit breaker... thats taking into consideration from what your describing that ALL other windows operate normally and that there are no aftermarket accessories
