Driver's Seat Won't Work
williebm3
Recently purchased 2007 Denali and now the driver's seat will intermittently not work. When not working the power pedals do not work either. PITA right now as wife and I both drive. Has Memory Seat Recall and it seems to only work when the seat works. Need some direction to go in any direction would be greatly appreciated.
guy from norcal
Check the wires under drivers seat. I had a wire rubbing on the seat rail that would blow the fuse for the seats.
Tw1st3dm3ch
Wylie, TX
Check the harness under the carpet too, had to fix a lot of broken wires in these for the same problem. The seat moving back and forth creates a break in the wires.
Tmart1990
