Driver's Side Heated Seat Stopped Working
IRQVET
2 Door Owners Club
Tallahassee, FL.
So my heated seat on the driver's side stopped working. My passenger side seat heater is working fine, so the problem is isolated to just the driver's side.
Anyone else have this problem, and if so, how do you fix it?
mharders
Just outside of Seattle
This has happened to many of us including myself. There is plenty of info on this. Just have to search. But 9/10 it's the heating element that burnt out.
Young28
The Yukon God
ga
yep happened to me. fixed it, then it happened again so i said to hell with it.
IRQVET
IRQVET
2 Door Owners Club
Tallahassee, FL.
I ran a search on this website, and got nadda. Can anyone help me find the thread, or give me the part number for a new heating element?
:Handshake:
james john
pequea pa
no heat in drivers seat in 99 hoe
my 99 Tahoe also has prob with drivers heated seat the book says pass seat needs seat belt hooked up not drivers. mine does not work with seat belt or not
SunlitComet
OBS Jedi-Do Good
unknown at this time.
bottom nor seat back? in high or low? use the diagram (print it out too) below to make sure power is getting to the module and that the switch is functioning properly.
Heated Seats Schematics: RR HVAC And FRONT HEATED SEATS Fuses, LF Heated Seat Module, G202
79171929
Heated Seat Inoperative
Symptom Related Diagnostic Procedures
170615822
Heated Seat Inoperative (Part 1 Of 3)
170615823
Heated Seat Inoperative (Part 2 Of 3)
170615824
Heated Seat Inoperative (Part 3 Of 3)
sandboxrocker
Southern Colorado
this is what mine is doing. When the vehicle is started with the remote start the drivers side works fine both bottom and back the minute you put key in and turn to run the bottom goes out and can not be turned back on even with the switch.... anybody want to try and figure that one out?
Haunted Denali 77
