DRL/Low Beams Intermittent
dachrist
I have an issue with my DRL/Low beams. I noticed that sometimes the DRL are not on, and when switching my headlights on (using the switch), the running lights come on but no low beams (low beam and DRL use the same bulb). I can turn my high beams on with no problem. The problem seems intermittent (the DRL/Low beams work most of the time). I never use the tilt wheel so I don't think its in the column wiring. Anywhere else I should look?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
perhaps the drl relay is getting dirty both circuits run thru there. located on the convenience center mounted on inside of fire wall.
HDRock1
Flint,Mi
If U save the pics to your pc U can zoom on them
(DRL) Relay
(1) Convenience Center
(2) Audio Alarm Module
(3) Turn/Hazard Flasher
(4) DRL Relay
(5) Fog Lamp Relay
(6) Park Brake Warning Switch
DaisyGirl
