andrewg29
- Joined
- Jun 14, 2014
- Posts
- 96
- Reaction score
- 0
So i finally decided to do the e fan conversion but instead of the flex a lite or dorman versions where you have to get the computer programmed i went with two 16 inch universal pro comp fans and a derale single stage fan controller. I got the fans mounted on the radiator but the only way i can get the fans to run is if i wire them straight to the battery in return will run all the time. The kit came with a temp probe 180 on 165 off. Any wiring info on how to get these things wired up will be greatly appreciated.
